עמוד 2 מתוך 8 ראשוןראשון 1234 ... אחרוןאחרון
מציג תוצאות 26 עד 50 מתוך 176
נושא: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
  1. #26
    Dec 2009
    הודה 45 פעמים ב 43 הודעות
    ברירת מחדל תגובה להודעה: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    hardly seen are panel lines engraved in the surface....
  2. #27
    Dec 2009
    seen here are the secondary flap with some small torsion spring made of 0.8mm piano wire glued to the surface with DP460 Epoxy.
Name:	Yellow Aircraft  F-18C twin build  project 013.jpg‏
ID:	27272   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 014.jpg‏
  3. #28
    Dec 2009
    Preparation of servo hatches...
Name:	Yellow Aircraft  F-18C twin build  project 016.jpg‏
ID:	27526   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 017.jpg‏
ID:	27527   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 018.jpg‏
  4. #29
    Dec 2009
    Filling the fuselage separation mold line with car putty...
Name:	Yellow Aircraft  F-18C twin build  project 019.jpg‏
  5. #30
    Dec 2009
    fuselage seam line filled ,sanded flush and coated with primer....
ID:	27606   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 020.jpg‏
ID:	27607   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 021.jpg‏
ID:	27608   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 022.jpg‏
  6. המשתמשים הבאים אמרו תודה לMCMF על הודעתו:
    tomerhasson (25-05-2018)
  7. #31
    Dec 2009
    more work on the wings....flaps at fully deployed position, "takeoff" and flight...
Name:	Yellow Aircraft  F-18C twin build  project 025.jpg‏
ID:	27610   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 024.jpg‏
ID:	27611   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 026.jpg‏
ID:	27612   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 023.jpg‏
  8. #32
    Dec 2009
    Final fit work on gear doors done......
Name:	Yellow Aircraft  F-18C twin build  project 028.jpg‏
ID:	27718   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 027.jpg‏
  9. #33
    Dec 2009
    Next are some shots of the scale simulated wing folding hump on the top of the wing.....
Name:	Yellow Aircraft  F-18C twin build  project 029.jpg‏
ID:	28014   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 030.jpg‏
ID:	28015   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 031.jpg‏
ID:	28016   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 032.jpg‏
  10. #34
    Dec 2009
    Fins under work,filling gaps,:mad applying primer..... sanding
Name:	Yellow Aircraft  F-18C twin build  project 033.jpg‏
ID:	28075   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 034.jpg‏
ID:	28076   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 035.jpg‏
ID:	28077   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 036.jpg‏
  11. #35
    Dec 2009
    Applying engraved panel lines
Name:	Yellow Aircraft  F-18C twin build  project 039.jpg‏
  12. #36
    Dec 2009
Name:	Yellow Aircraft  F-18C twin build  project 040.jpg‏
  13. #37
    Dec 2009
Name:	Yellow Aircraft  F-18C twin build  project 041.jpg‏
  14. #38
    Dec 2009
Name:	Yellow Aircraft  F-18C twin build  project 042.jpg‏
  15. #39
    Dec 2009
Name:	Yellow Aircraft  F-18C twin build  project 043.jpg‏
  16. #40
    Dec 2009
    Stabilizers finish under go...
Name:	Yellow Aircraft  F-18C twin build  project 037.jpg‏
ID:	28186   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 038.jpg‏
ID:	28187   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 044.jpg‏
  17. #41
    Dec 2009
Name:	Yellow Aircraft  F-18C twin build  project 045.jpg‏
  18. #42
    Dec 2009
    Next I deal with the splitter plates, first step is laminating 1/8 balsa plank on the inner surface of the part and sanding down to a minimum the LE's
    after that covering the surface with 120g cloth and resin ....
Name:	Yellow Aircraft  F-18C twin build  project 046.jpg‏
ID:	28474   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 047.jpg‏
ID:	28475   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 048.jpg‏
ID:	28476   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 049.jpg‏
  19. #43
    יש לו"ז לסיום ?
  20. #44
    hasaron
    מה עם פינאלה?
    זה הפרוייקט הכי מושקע שיש סחתיין!!
  21. #45
    Dec 2009
    2~3 חודשים לסיום.....מעייף.
  22. #46
    Dec 2009
    Cool תגובה להודעה: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    After glassing ,sanding filling and co for so long I've decided to do something diffrent today.....
    Preparation of possition lights red port side first...
Name:	f-18 twin position lights 001.jpg‏
ID:	28609   Click image for larger version.
Name:	f-18 twin position lights 002.jpg‏
ID:	28610   Click image for larger version.
Name:	f-18 twin position lights 003.jpg‏
  23. #47
    Dec 2009
Name:	f-18 twin position lights 004.jpg‏
ID:	28612   Click image for larger version.
Name:	f-18 twin position lights 005.jpg‏
ID:	28613   Click image for larger version.
Name:	f-18 twin position lights 006.jpg‏
  24. #48
    Dec 2009
    more....
  25. #49
    Dec 2009
    more...
Name:	f-18 twin position lights 009.jpg‏
ID:	28620   Click image for larger version.
Name:	f-18 twin position lights 012.jpg‏
ID:	28621   Click image for larger version.
Name:	f-18 twin position lights 011.jpg‏
ID:	28622   Click image for larger version.
Name:	f-18 twin position lights 010.jpg‏
  26. #50
    Dec 2009
    more
Name:	f-18 twin position lights 015.jpg‏
ID:	28624   Click image for larger version.
Name:	f-18 twin position lights 013.jpg‏
ID:	28625   Click image for larger version.
Name:	f-18 twin position lights 014.jpg‏
  1. שרשור בניה של F-15 של חברת FLY EAGLE JET
    על ידי MCMF בפורום פורום JET-ים
    תגובות: 50
    הודעה אחרונה: 08-06-2010, 14:46:34
  2. שרשור בניה
    הודעה אחרונה: 09-05-2010, 21:07:44
  3. סוייפטאלי שרשור בניה
    על ידי mus בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 19-04-2010, 00:59:43
  4. [שרשור בניה] שרשור בניה - Jetlegend T-45
    על ידי ליאור זהבי בפורום פורום JET-ים
    הודעה אחרונה: 10-01-2010, 13:51:57
  5. [שרשור בניה] אני פותח שרשור בניה חדש שלי...
    על ידי zahi101 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 106
    הודעה אחרונה: 10-08-2009, 16:41:20
